cycojon
addicted to my superjet
- riverside ca
i am re-foaming my tray on the superjet, installing a scupper and fixing leaks. i am pulling all the foam out.
my question is, when i pour the new foam in should i pour in a little and let it expand then pour some more, and keep repeating untill its full? or should i pour in alot (how much i don't know, i got the 16lb kit on the way) and let it expand out of the holes i am pouring into? or, do i cover these holes after i pour and let the foam expand in the tray.
when i did my foot holds i poured in too much foam and when it expanded out of the hole i coverd it and then my foot hold kind poped out just a little in the middle. that was my first time. the second time i just let it rush out and it was fine.
what i was thinking of doing is glassing in my tray and getting everything sealed up and then standing it up on end and pouring foam in through the original holes in the engine compartment then glassing over those when i re-enforce the inside.
is it best to refoam useing these holes or should i put holes in the tray where you stand when you ride and foam through there?
also
should i put holes in the top of the sides of the tray to make sure i get foam behind the foot hold or will it make its way up there if i stand it on end?
thanks in advance
also
thanks in advance
