- Shark River, N.J.
Hello, 2000 RN been having a problem with exhaust leak and water cooling leaking into hull. I had water leaking from cooling system for most of last season, but It has been manageable enough to just turn bilge pump on for a bit to take care of it, but now it has increased greatly. Exhaust problem was a leak from the manifold- had to drill and tap from m-8 to m-10. That seemed to solve the exhaust leak but on the next ski I had an even bigger water leak. So I finally decided to pull the motor and trace the water leak problem. I pulled motor and found a few potential problems that could cause the leaks, and will replace the water lines. Then I turned the drive shaft to the impeller to check it. It turned very smooth but had play in it, probably about 1/4". Is this normal for the mid shaft? Any thoughts would be greatly appreciated. Thanks, Griggsmars
