vitalikol
Jetski-Snowboard
- Pennington,NJ
I going to install two 44mm carbs on Kawi 750 motor (had just one carb before). can I split pulse line and run it to both carbs ??? Or I Really need to dreel a hole in other side and put fitting for second carb ?
If I split it , will signal be too weak ???
New Q ? Where to get second fitting ?
Last time I did it, I drill and epoxy fitting in. Somebody was saying drill and tap. What fitting to use then ?
