- Birmingham, AL
I just installed dual Novi 48mm carbs on my superjet. The diagram that came with the setup shows a pulse line coming from each manifold intake port with them being routed independently to each carb. My manifold only has one vacuum fitting, which is located on the driveshaft side of the engine. My question is this: can I 'get by' if I simply tee/wye the single fitting to each of the carbs or do they strictly require the independent routing as shown?
Thanks!
Thanks!
