Super Jet Pump/hoses help
please help lol I bought a project ski (97 round nose) and I went to install/shim the pump and realized the pump only has two places to put hoses, 1 3/8 nipple I'm pretty sure is for cooling but there is a 3/4" nipple on the other side of the pump and there are 2 3/8" hoses that come out of the hull I've never messed with pumps so I'm not sure what the 3/4 hose is on the pump I'm assuming 1 of the hoses coming out of the hull are a syphon bilge but I'm not sure
[/IMG]
[/IMG]
[/IMG]
the one on the right cut off half of whats sticking out for clearance to fit in the hull then tap for a fitting !
what size would i tap it? the hole has a 3/4" (.075") I.D. should i just cap the hole? I'm running a stock engine no need for dual cooling at this time. should i cap the hole and drill and tap a 3/8 barbed hose fitting some where next to it?
any one else ever had to deal with this?
oakland
Yes you can cap it and run single cooling
oakland
1490329189233-176223498.jpg I have a bunch of stator for either single or dual cooling u can have one if you need it no worries I'll be heading to folsom in the next week or so
