JetManiac's Pump Shop
Driveshafts and Midshafts (Coupler/Intermediate shaft)
'90-'07 SJ length nontapered HD driveshaft 169.
'08-'14 SJ length driveshaft 179.
'93-'96 Waveblaster WB1 driveshaft 169.
Setback driveshafts for
Skat Trak,
H2O, and
Maxx MAG pumps
Custom length driveshafts available
(B stock shafts are sometimes available for 119.-139.)
Midshaft/coupler shaft SJ or Blaster new a/m 89.90
or
Cold Fusion SJ midshaft 138.
MAG Pumps
Skat Trak Setback or Nonsetback 144, 148, and 155mm MAG pumps
http://www.x-h2o.com/index.php?thre...back-driveshaft-and-c-75-impeller-1580.82606/
Solas MAG pump
http://www.x-h2o.com/index.php?threads/solas-mag-pump-144mm-12vane-ss-for-yamaha-475.108950/
Pump and Midshaft Rebuild Kits
Pump Build/Rebuild kit (2 bearings/2 seals/o-ring) 39.
OEM Pump Build/Rebuild kit (2 bearings/2 seals/o-ring) 89.90 discount to 76.
Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips) 39.
Pump Parts
Pump stator vane section 144mm for SJ/Blaster (used, clean) 75.
Pump stator vane section 144mm for SJ/Blaster (used, average) 50.
Pump Seal (wear ring to pump shoe) 144mm new a/m 21.
Pump Seal (wear ring to pump shoe) 144mm new OEM 29.
Pump Seal (wear ring to pump shoe) 155mm new a/m 39.90
Long 144 pump bolts -New OEM 6.95/ea.
144 Pump to hull bolts -New OEM 6.95/ea.
Pump SS shim kit 19.
Driveshaft spline tool for impeller removal/installation 16.
midshaft spline tool (for midshaft coupler removal/installation) 19.
Skat Trak or Hooker impeller tool 16.
Solas impeller tool 15.
Skat Trak or Hooker impeller nose boots 8. (specify tapered or nontapered shaft)
Impeller washers (2mm) OEM 8.
Impeller spacer washer SS a/m (0.8 or 1.5mm) 6./ea.
Impeller spacer kit (all 3 sizes) 19.50
Brass Water Fittings for dual cooling on exhaust manifold, pump, and head
3/8" hose fittings 5.
1/2" hose fittings 6.
Impellers
Impros HOOKER Freeride Impellers
The Impros Hooker 144mm impeller for the Yamaha is a 3 blade large hub diameter, radial edge design polished stainless steel impeller designed and intended for bottom end power and "Hook up" (hence the name Hooker) for freestyle and freeriders on a Superjet, Blaster, or similar ski that utilizes the 144mm Yamaha pump.
Designed around maximizing pump efficiency and bottom end, this is a new radial edge design, large hub (75mm), and is set back 7mm.
Hooker fits stock 144mm Yamaha pump, Skat Trak Magnum pumps (with shim), and TBM/other brand Super Pump Cone.
Impeller includes nose seal and hooker impeller tool.
New Impros
HOOKER Freeride Impeller 279. special 265.
9/15, 10/16, or 11/17
Skat Trak MAG Pump Impellers
Skat Trak C75 Big Hub
144mm 14/19, 13/18 Impeller NEW 268.
Skat Trak D75 Big Hub
148mm Impellers
Skat Trak E75 Big Hub
155mm Impellers
Freestyle pump cones
Wet Wolf stubby pump cone (for OEM yamaha pumps 144 and 155mm) 55.
XScream lightweight composite cones for MAG pumps 55.
(3 lengths available)
Impros freestyle stubby cone for
Solas MAG pump 55.
Wear Rings
(More information about wear rings in post 3 below.)
SBT 144 wear ring with replaceable delrin plastic liner 139.
OEM Yamaha new wear ring for SJ/Blaster 274. Sale 239.
Replacement delrin liner for SBT or WSM 35.
OEM 144mm impeller housing/wear ring for SJ/Blaster (used, freshwater, clean) 89. (when available)
Solas all Stainless Steel wear ring 299.
144mm Pump wear ring to pump shoe seal 21.
155mm Pump wear ring to pump shoe seal 39.90
Taper-Bored Reduction Nozzles
These metal reduction nozzles have been newly taper-bored to 85mm by #zero. High quality machining work, almost too nice to install, pics do not show how nice they are. The nozzles have also been refinished and are ready to install. They are designed to increase water flow through the pump to help with low end freestyle performance.
144mm size for Superjets or Blaster 1's
Standard no trim style Bored Reduction Nozzle 99.
62t Bored Reduction Nozzle for use with Trim system 169.
(for CATS, Xmetal, Thrust, etc.- also have 5 deg up nozzles)
(without stock siphon bilge fitting)
155mm Bored Reduction trim nozzle 179.
Add a quick turn modified steering nozzle for 49. add'l no trim
Add a quick turn modified steering nozzle for 55. add'l trim
Pump Shoes
OEM Yamaha Pump Shoes
Superjet 1990-2013 OEM 144mm pump shoe reg. 110. sell 89.90
Waveblaster 1 1993-1996 OEM 144mm pump shoe reg. 150. sell 129.
Waveblaster 2 1996-1997 OEM 155mm pump shoe reg. 129. sell 109.
Aluminum Pump shoes
Blowsion Aluminum 144-148mm pump shoe 96.
Jet Dynamics Aluminum 144-148mm pump shoe 117.
144-148mm Pump wear ring to pump shoe seal 21.
155mm
Yamaha 155mm
Jet Dynamics aluminum pump shoe 117.
RRP rickter aluminum 155mm pump shoe 149.
Yamaha 160mm
