JetManiac's Pump Shop
Driveshafts and Midshafts (Coupler/Intermediate shaft)
'90-'07 SJ length nontapered HD driveshaft 189.
'08-'17 SJ length nontapered HD driveshaft 189.
'93-'96 Waveblaster WB1 driveshaft 189.
Setback driveshafts for
Skat Trak,
H2O, and
Maxx MAG pumps
Custom length driveshafts available
(B stock shafts are sometimes available for 119.-159.)
Midshaft/coupler shaft SJ new a/m 94.90
Cold Fusion SJ/B1 midshaft 138.
OEM SJ midshaft 239. Sale 195.
MAG Pumps
Skat Trak Setback or Nonsetback 144, 148, 155, 160mm MAG pumps
http://www.x-h2o.com/index.php?thre...back-driveshaft-and-c-75-impeller-1580.82606/
Solas MAG 144 and 148mm MAG pumps
http://www.x-h2o.com/index.php?threads/solas-mag-pump-144mm-12vane-ss-for-yamaha-475.108950/
Torrent 155mm MAG setback pump stator/wear ring 1,699.
Torrent 148mm MAG setback pump stator/wear ring 995.
Torrent 148mm MAG Nonsetback pump/wear ring 949.
**Available as pump only or in kit with driveshaft, Skat impellers also available
Pump and Midshaft Rebuild Kits
Pump Build/Rebuild kit (2 bearings/2 seals/o-ring) 39.
Koyo Jap Oem brand pump rebuild kit (2 bearings/2 seals) 89.90 sale 59.90
OEM Yamaha Pump Build/Rebuild kit (2 bearings/2 seals) 89.90 sale 76.
Setback MAG Pump Build/Rebuild kit (2 a/m bearings/2 seals) 59.90
Setback MAG Pump Build/Rebuild kit (2 Koyo bearings/2 seals) 99.90
Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips) 39.
Koyo Jap Oem brand Midshaft Build/Rebuild kit (Bearing/3 seals/2 orings/clips) 54.
Pump Parts
Pump stator vane section 144mm for SJ/Blaster (used, clean) 75.
Pump stator vane section 144mm for SJ/Blaster (used, average) 50.
Pump stator vane section 155mm 89.
Pump Seal (wear ring to pump shoe) 144mm new a/m 21.
Pump Seal (wear ring to pump shoe) 144mm new OEM 29.90
Pump Seal (wear ring to pump shoe) 155mm new a/m 39.90
Long 144 pump bolts -New OEM 6.95/ea.
144 Pump to hull bolts -New OEM 6.95/ea.
pump bolt to hull tray brass OEM threaded insert 4.50
Pump SS shim kit 19.
Driveshaft spline tool for impeller removal/installation 16.
Midshaft spline tool (for midshaft coupler removal/installation) 24.50
Skat Trak or
Hooker hex impeller tool 21.90
Solas impeller tool 15.
Skat Trak or
Hooker impeller nose boots 8. (specify tapered or nontapered shaft)
Impeller washers (2mm) OEM 8.
Impeller spacer washer SS a/m (0.8 or 1.5mm) 6./ea.
Impeller spacer kit (all 3 sizes) 19.50
Brass Water Fittings for dual cooling on exhaust manifold, pump, and head
3/8" hose fittings 5.
1/2" hose fittings 6.
Impellers
Impros HOOKER Freeride Impellers
The Impros Hooker 144mm impeller for the Yamaha is a 3 blade large hub diameter, radial edge design stainless steel impeller designed and intended for bottom end power and "Hook up" (hence the name Hooker) for freestyle and freeriders on a SJ or Blaster that utilizes the 144mm Yamaha pump.
Designed around maximizing pump efficiency and bottom end, this is a new radial edge design, large hub (75mm), and is set back 7mm.
Hooker fits stock 144mm Yamaha pump, Skat Trak Magnum pumps (with shim), and TBM/other brand Super Pump Cone.
New Impros
HOOKER Freeride Impeller 279. special 265.
9/15, 10/16, or 11/17
Impeller includes nose seal and hooker impeller tool.
Hooker for Kawi 140mm pumps 279. special 265.
Skat Trak MAG Pump Impellers
Skat Trak C75 Big Hub
144mm Impeller 289.
Skat Trak D75 Big Hub
148mm Impellers 289.
Skat Trak E75 Big Hub
155mm Impellers 289.
5mm cutback option 30.
Solas impellers
Solas 144 Concord impellers
Solas 148 Concord impellers
Freestyle pump cones
Wet Wolf stubby pump cone (for OEM yamaha pumps 144 and 155mm) 55.
Impros freestyle stubby cone for
Solas MAG pump 55.
XScream lightweight composite cones for Skat MAG pumps 55.
(3 lengths available)
Torrent Mag pump stubby cone 55.
Wear Rings
(More information about wear rings in post 3 below.)
SBT 144mm wear ring with replaceable delrin plastic liner 139.
OEM Yamaha new 144mm wear ring for SJ/Blaster 274. Sale 239.
Replacement 144mm delrin liner for SBT or WSM 38.50
OEM 144mm impeller housing/wear ring for SJ/Blaster (used, freshwater, clean) 89. (when available)
Solas all Stainless Steel 144mm wear ring 299.
144mm Pump wear ring to pump shoe seal 21.
155mm Pump wear ring to pump shoe seal 39.90
Replacement 155mm delrin liner for SBT or WSM 38.50
155mm B2 wear ring with replaceable plastic liner 149.90
Taper-Bored Reduction Nozzles
These metal reduction nozzles have been newly taper-bored to 85mm by #zero. High quality machining work, pics do not show how nice they are. The nozzles have also been refinished and are ready to install. They are designed to increase water flow through the pump to help with low end freestyle performance.
SuperJet or Blaster 144mm non-trim
Standard no trim style Bored 144mm SJ/B1 Reduction Nozzle 99.
144-148mm trim nozzles
62t Bored trim reduction nozzle 169.
(for homemade CATS, Xmetal, Thrust, and other trim systems)
(without stock siphon bilge fitting)
5deg up Bored trim reduction nozzle 169.
155mm Bored Reduction trim nozzle 179.
5 deg up 155mm Bored Reduction trim nozzle 179.
Steering nozzles
OEM 61x new no-trim steering nozzle 55.
or
OEM 61x clean, used no-trim steering nozzle 34.
OEM steering nozzle bolts and stainless bushings 7./set
OEM 62t new trim steering nozzle 55.
or
OEM 62t clean, used trim steering nozzle 35.
OEM trim ring bolts and stainless bushings 7./set
Pro Tec aluminum trim steering nozzle 109.95
Thrust aluminum trim steering nozzle 125.
Trim systems and parts:
Thrust, RRP and Xmetal:
http://www.x-h2o.com/index.php?threads/trim-systems-from-jetmaniac-thrust-and-xmetal.141581/
