- deland fl
while this site was down, i took this question to the other site but since it wasn't about which wax is better or top speed runs no one is commenting...j/k
maybe ya'll will help me out:
i am rebuilding a housing i bought to put in my ski. not sure what it came out of but the bolt holes line up like they should, which was the only possible difference i thought.
i bought a wsm bearing and seal kit and the bearing in the kit is about 2/3 the width of the bearing we pressed out. the int diam. and outer diameter appear the same, just the width is different.
anyone run into that and does the width matter. i assume since you have to press it in, it wouldn't be moving around in there, plus int. shaft doesnt move around front to back right?
any thoughts???
thanks
any thoughts???
thanks
