Other Quick carb cleaning question
Magyar68
Really!!!
Lewisville
NO you should not need to remove the Butterflies, the screws that hold them in are Stamped on the bottom so they will not come out during normal operation of the Ski. if the carbs are leaking out of the Seals on the throtle shaft the removing the shaft to replace the seals is warranted..
agua
FIshing for Stand ups
Seminole, Fl
open it up and spray out everything with carb cleaner, clean the jets out and make sure you know how far they are turned out
