227
Its all about the surf!
- Oceanside, CA
Here's the 15 minute fix- Drill a 6mm hole through the pole stop post and put a 6mm ss bolt through it. Add ss washers to either side of bolt (head and nut) so the bolt head/nut is now the stop. (After adjusting, You will most likely have to hack off a small portion of the bolt on the nut side so the entire nut will be the stop on that side). Does that make sense?
