R&D Dominator Manifold Differences
Alright so I'm looking to pick up a dominator manifold and I understand they make one manifold for OEM reeds and one for Vforce reeds in addition to the on that they make for the M-16's. Does anyone have any pictures of both or know how to differentiate between the two? I've got a set of Vf II's and want to make sure I buy the right manifold.
Thanks
Why not the Boysean?? Works the same. Uses Orings for the seal at the plate to manifold. slight mod to OEM Cages and it works great.
hmmm. never thought about it. I'm assuming they will also accept the VF II's with a slight modification? how much are they new? unfortunately ive never seen one used.
I really don't understand why there is a difference between the VF II's and OEM R&D manifolds. I thought the reed cages were essentially the same as far as mounting and dimensions?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
If your going to run the V2 reed cages just get the R&D manifold (if you can get them) for them, It's a lot of grinding work to use the std oval one and open it up to fit the V2's.
godocgo
sport
s. fla
i can never find the long rubber coupler piece, i always end up changing out the shaft :(
