R.I.P. Frankenstien
WaveDemon
Not Dead - Notable Member
Hell, Florida
made from parts no one else wanted and made more power then anyone thought it could my Frankenstein had a catastrophic failure today. Rust In Piece.
I knew it was bad when it happened. It went from high rpm to stopped instantly. It also wasn't a good sign when Tom21 spotted a cylinder sleeve piece in my hull on the beach.
Looks like the 66e project will get moved up. :bananalama:
WaveDemon
Hell, Florida
more
WaHoo_1
Surf Swimmer
Tampa, FL
dayum, nice carnage you beast! :bigeyes: I remember when you first put that thing together. Think you got your $ outta her. RIP!
tom21
havin fun
clearwater FL
this is posted in the wrong thread- It should be in the build section of your ski. The motor is finally up to speed with the rest of ski. Well done!!!:notworthy:
:bow28:
by the way- I never imagined it would be that bad. dibs on the hardware and engine mount brackets!!! doesn't look like much else is usable.
#ZERO
Beach Bum
Florida - U.S.A.
Tom... you should be able to weld that right up. :chairfall:
Tim... I knew you were running on barrowed time with that engine. :theyareontome:
