- Valley Springs, CA
Couple pics of R & R tech
Alright guys. I had to take the engine apart. Here is the porting on the intake. Is it any good? I can get pictures of other parts of it if you want.
Sent from GS3 Synergy
There is nothing to see there
Not to be a douche, but from one douche to another, it helps if you explain, because all of the intakes I've seen are flat. Does it in fact have work done to it or no?
Those two pictures show the bottom of the sleeves sticking down below the bottom of the cylinders....... No Pictures of the of ports are show. Transfers or Exhaust, No pictures of the of the tunnels leading up the sides of the cylinder walls to the transfers........... You did not post any pictures that anybody can look at and begin to give you any idea of what you have............................
Honestly, Personally when you start a sentence off with "Not to be a douche", usually you end up acting just like that................
