RAD 760 aluminum charging flywheel
long beach local
long beach local
Az
If you have all the 760 stuff already go zeeltronic total loss and lighten your flywheel and you would have a superior setup. You can still get a couple long rides with a good battery and keeping it charged is not that big of a deal I don’t think.
Im already running zeel but i just cant run total loss i do long rides usually. And half the time ill kill batteries running a charging system lol
Sent from my SM-N975U using Tapatalk
long beach local
long beach local
Az
What kind of battery are you running ? Are you running a bilge full time? I can ride at least 2 tanks easily more if necesary But I usually put it on a specific charger that’s turns off automatically and charges quick costs about 50$ To be safe but the zeel uses very little unless your constantly using the starter. Although I run large Good batteries either a battery mart 500cca Lithium or a 13lb odyssey I have never had one die in 1 ride.
Its 100% all me on the starter. last outing was about 15 gallons in 4 hours and killed battery from water ingestion had to get towed back 12 miles. Im running a 5 ah lithium no bilge. Total loss just isnt for me maybe if i didnt land upside down so much or if i stayed at a beach all day but that tends to only be on holiday
In other words i suck and still need charging
