- Sacramento California
Would be awesome if someone had a rad 760 aluminum flywheel i could buy
Sent from my SM-N975U using Tapatalk
Im already running zeel but i just cant run total loss i do long rides usually. And half the time ill kill batteries running a charging system lolIf you have all the 760 stuff already go zeeltronic total loss and lighten your flywheel and you would have a superior setup. You can still get a couple long rides with a good battery and keeping it charged is not that big of a deal I don’t think.
I dont think there were that many made but iv seen a few pop up over the yearswas an aluminum 760 flywheel ever made?
What kind of battery are you running ? Are you running a bilge full time? I can ride at least 2 tanks easily more if necesary But I usually put it on a specific charger that’s turns off automatically and charges quick costs about 50$ To be safe but the zeel uses very little unless your constantly using the starter. Although I run large Good batteries either a battery mart 500cca Lithium or a 13lb odyssey I have never had one die in 1 ride.
