Custom/Hybrid Rad Dudes Top Secret Rickter Daytona Build
Powder coated box with all the quick disconnects now.
Bilge switch build into the start stop. Thanks to trust for the switch. This is a nice clean way to mount it.
[/QUOTE]
Do you have that start stop switch fastened to the handle bars with the plastic nipple inside the switch housing that fits in a hole drilled in the handle bars? I had mine mounted the exact same way and didnt want to drill the hole in the bars, after a couple times of the housing spinning it tore open the rubber switch housing and the salt killed it in 2-3 rides. Sucked big time those switches are not cheap. Just my .02
The Turf master Keith spend a nice 12 hour day on this bad boy today.
He's the best in the biz
Foot holds are not bolted in yet. But look how nice and wide she is.
I'll rate it a 8 outta ten. It was a long day of huffing fumes. First time turfing a rickter and pancake pete foothold some interesting lines to work around
