here's a couple of pics of my RAD total loss flywheel after having timing issues this past week. Paul Lehr suggested I look at my flywheel as a source of timing changes that occured spontaneously after my ski stopped suddenly after a few nose stabs. I pulled the flywheel and found that the woodruff key has dug into the flywheel. As a result of what??? I've done a thousand nose stabs/attempts and never noticed anything like this occuring. My timing was off about 4-5 degrees when I checked it yesterday and I pulled the added timing off with the brain and it ran fine until I tried another nose stab yesterday and the same results happened. I assumed the pickup plate had moved, but those bolts were snug as was the flywheel when I pulled it. Look at my drive shaft as well. The woodruff key is stuck in the recess and has actually dug itself into the shaft too!! U guys have any thoughts? I'm assuming the flywheel is trash. What do you guyhs think. There's some play in the flywheel when I rebolt it. How do I get that dang woodruff key out?
