Not can do. Sold it for a factory pipe. I needed access to tightening head bolts without having to remove the pipe and engine. Plus, tired of it loosening up. I played with the water settings all summer let summer. Tried to dry it out for more rpm. I found the I lost the low end which made the ski more fun. Honestly, you could lose the pisser off the line from back of pipe to stinger for best low end. That pipe loves water for low end. Also a jetworks valve right before stinger helps to keep the water from building up in the water box during idle. I also used a jetworks restrictor control knob on line from pipe to stinger to see what the best setting was for low end. The setting is completely closed. Pipe never gets too hot. Good luck.
