Reed or carb failure?
Ohio
Went through carbs and all looks fine inside on both sides! Snuck a tiny mirror behind the flywheel a tad and all looks well....dry and fresh and no grindings of any kind.
I am a little lost on this one.
Stockton
Fwiw, if you pull the flywheel bolt and look up into the flywheels hub, all you can see is the tip of the woodruff key… when they shear, one section follows the flywheel and looks fine while the other section stays with crank. In my experience, when the key way shears, you start getting a backfire and no start/ no run condition….due to incorrect timing.. best way to check the key is remove the flywheel..
At this point it might make sense to temporarily reinstall the cover and swap in a known good cdi ?
Then if still needed, pull the flywheel and inspect the key and swap in a known good stator…
I assume the butterfly’s both open evenly ? There was another thread by Paul1 I think out of Canada on a running issue and reed inspection… I’ll look for it…..
He didn’t list a symptom
Ohio
OK back on it at some point today. Yes the butterfly's both operate perfectly and in sync and she even appears to start and idle fine.
I just can't even touch the throttle or I get instant and heavy bog.
Argo, Al
Yeah or possibly water in the fuel? Either way it kind of sounds like a fuel issue. Clogged internal filter, plugged pilot jet?
Also I agree with Harbor on the sheared flywheel key. Had it happen one time and the ski wouldn’t even start, just backfired.
Ohio
I thought about bad gas/water but man it came on suddenly as I was shredding. Just riding around and bam.....
I don't have the internal filters anymore. I'll look at the pilots more closely as soon as I go outside..
I’m still saying you have an electrical issue. CDI, plug boot or plug wire, maybe coil. I had a plug boot go bad. It was sudden. When I got on the throttle it ran on one cylinder.
If something in the fuel system was restricted, your plugs would be looking lean, but yours are wet like you’re getting unburnt fuel
Ohio
Ahg I wish I would have started with the flywheel! It appears I am lucky and no damage done.
In the light I could see the crust on the flywheel bolt was dried red thread locker so I can see I did that properly. Although it is all high on the threads and I thought that was odd. I can't imagine I didn't torque it properly.
Ohio
For some reason I thought I read you already ruled the flywheel area out
Lightly ruled it out LOL. All APPEARED to be OK!
I swear man anytime I pick a direction to chase on a ski I choose the wrong one first! Every time! Even if I purposely choose the opposite of what I actually chose it flips on me and still leads me down the wrong path first! It has been this way for 20 years! Just jet skis!
strong beautiful sparks on both plugs....
It can look like that when you pull the plugs, but have weak to no spark under compression
Glad you found the issue. Did the flywheel turn? Timing off?
Ohio
I swear man this has happened in the past and it was worse....would not start and backfired like mentioned in here.
But this time it would start and idle! LOL.
Ohio
Yep it appears so....so far.....all I know is the flywheel bolt was loose when I went to take it off. I still had to use the puller to get the flywheel off and the key and key way look great! I don't get it. Moved forward on me?
