Remedy for Squeaky ATP Pole
I have a ATP pole and ATP pole bracket. It is so noisy and I cant take it anymore. I have tried taking it apart and greasing it and spraying it with WD40. Both of these made it silent for about 15 min of riding then it came right back. Any one have a solid fix for this? I am going to take my pole off/apart tonight to cut my tubes, I would like to cure this issue at the same time if possible.
NC
I had the same problem before. When you take it apart, lightly (LIGHTLY) sand the sides of the bushings where they touch the pole bracket with fine sandpaper.
I have never heard about the fabric softener but I have heard of sanding them. I will try sanding them first. If that don't work I will pull it back apart and try the fabric softener.
