Removing finish from an anodized part
XPracer
The original Mr. Mehoff
Jacksonville, FL
How would you do this? I have an aluminum part that is anodized this horrible purple color and I want to strip it down to bare aluminum and polish it. I'm sure it's probably a p.i.t.a. Can I sandblast it off?
Caustic soda will do the trick. wrecked a lot of bmx parts in the 80's with the old draino method.Wear gloves and eye protection as it is nasty stuff.
BombThreat
'Diggity
Johnstown, NY
mix one bottle of red devil 100% lime (8oz i think) to a gallon of warm water. make sure the part is real clean before putting it in because the lime will eat around the dirt and leave a spot. it should only take 10-15 minutes to rub off with a cloth. when done rinse thorough in water.
DAG
Charlotte, NC
dip, sit, wipe...
WORKS WONDERS
After you remove the coating and polish the part you will have to clear it or something or it will dull and corode prety fast. I polished the pissers on my ski (i was bored one winter) and they looked like crap in a few months.. So I painted them with that new Metallic paint that looks like anodizing. The best thing on the market. Just polish them up and spray and they look anodized
aqua
the taco
i would just use a gritty polish to polish the anodizing off. by the time you get through it I would think that you would have a nice polished surface. You have to polish it anyway right? Or maybe use some fine grit wet dry paper to sand the anodizing off and finish with a polishing compound.
pjsrider
PJS VIPER RIDER
Central Florida
dip, sit, wipe...
WORKS WONDERS
Can you elaborate on this process? Do you dip it then pull it out and let it sit? Or, do you let the part sit in the solution for a while then pull it out and let it sit then wipe? Does the water have to be warm? I have grill out of a 74 truck that is anodized and I want to polish it. I guess I will need a large tub to do it in.
Jay
