Custom/Hybrid Resin dye?? What works?
JetManiac
Stoked
orlando
I have used the black dye/gel coat dye from west marine for my add on inserts for superfreak
SUPERJET-113
GASKETS FOR CHAMP BRAP!
You can also use tints from automotive paints. They are the straight tints from the can and are VERY concentrated so a little goes a long ways. You can go to the PPG/Sherman Williams automotive paints dealers and get a 1/4 pint of what color you want for cheap. Obviously lighter colors will require more pigment.
SUPERJET-113
might be a dumb question but...
does adding pigment / dye to the mix make it loose any kind of strength / adhesion?
Obviously your adding something that is not resin and is just straight color pigment, so yes it will make it weaker, but you use such a small amount its pretty much negligible.
