One more thing, on the pump system West System uses metered pumps, that means you push the pump down one time and it meters out the correct amount of resin and hardener. Everyone else I know of is different, lets take US composites for example, if using their 3/1 system you pump the resin three times and the hardener one time, both resin and hardener use the same pump. The West System metered pumps make it much easier to mix up small amounts of epoxy and it is virtually idiot proof.
