Custom/Hybrid Rickter foothold adjustment
I am having problems with my feet coming out of the footholds on my Rickter, and wondered how you guys set yours up. I feel like I need to be able to get my feet further into them, but they are opened up to the max amount at the back.
Has anyone else has had this problem and what did you do to fix it?
Any tips?
Any tips?
I've been fighting mine for a while, about to but some baseball or soccer cleats but it shouldn't be this difficult. I could use some help as well if anyone has any tips.
England
I drilled holes lower down on my old Evo's footholds to bring the whole hold up an inch or so, I added thicker padding and came across the same issue.
loosen the bolts, put your feet in the holds and push them down by hand to where they are comfortable and tighten them down while holding them at the desired pressure. Took me a few tried to find the right fit too.
