Rickter fs2 Evo built and tuned to perfection(Rip Ready)
- Some bumps and small bruises, but I own a body shop and would be willing to do any requested repairs for a minimal amount extra on the paint chips or small bruises. Or for a fair price, i could do anything you could dream with airbrush and clear coat.
- TNT Blowsion EXHAUST system
- THRUST best/biggest CARBS - Sick as can be! Great job guys!!!!
- RRP HANDLEPOLE
- HANDLEBARS RRP 3” riser bars, ADA turn plate
- RRP TRIM SYSTEM, WORX INTAKE GRATE, RRP RIDE PLATE, SOLAS JET PUMP and IMPELLER
- RRP Handlepole bracket, bolt, hood hooks, brackets, hardware, plus misc other expensive Blowsion and RRP parts I can’t take time to list
- SBP 2020 clear flywheel cover for lightened, charging flywheel, and Yamaha oem stator, jet maniac salt water coil, MSD CDI, H2O designs eBox(clear)
- RRP adjustable foot holds with conicle washers
- RULE Bilge pump and RRP scupper
- UMI ginger throttle
- thrust start stop easy aluminum housing
- bad arse fuel tank that holds the battery
- Blowsion waterbox
- Kenny keepers and RRP motor mounts and motor mount rail system
- Obviously everything not listed..... but it is a low hour(40-60 hours approximately on build) everything was purchased brand new for this ski.
- my loss(heartbreak) your gain..... need quick cash to make more cash. I Would probably buy it back in a month or three if you don’t ride it much or find Yourself with different interests.... this ski is built and tuned SUPER well.....
Not sure if phone numbers are allowed here, I forget, so PM me for more I fo or purchase arrangements.
Thanks!
$10k..... might trade for cash and something else? I just need some quick cash.
- RRP HANDLEPOLE
- Blowsion waterbox
Thanks!
