I did on my 14 Xfs and everything dropped straight in. No spacer. Except you will need to lengthen the long exhaust hose from your water box to hull. The Rrp pole tubes work great for this, just save the length that you cut off and use it as a coupler
I ran it for a almost a year before I sold itHow long have you been running this build?
As I understand it the mid shaft spaces is a preventative to allow the shaft to flex and not strip the splines. Would you or anyonen else say I need to put one in?
Thanks, I was just on the phone to a mechanic and he told me the the driveshafts are different lengths and he would need to make a modification? Did you convert from a Stock SJ?
Thanks for the help, I am going to do the build myself now as it sounds like it should all pretty much drop in.
Is there anything else I need to order other than exhaust tube, mid shaft spacer and handle pole?
It seems as though a few of you don't understand the purpose of a bulkhead spacer. Do as you thinks best op.
