SOLD Rickter xfs carbon core dasa 1100 $14500
2018 rickter xfs carbon core visual carbon
This ski was built by Dino werzel originally.
It was built in December last year.
It has a dasa 1100 10mm that was rebuilt at the same time.
Novi 48s with external fuel pump
Thrust pole with carbon chin pad
Thrust steering
tnt lay down exhaust and water box. stock charging electrics with msd enhancer
Thrust trim system
155 oem pump
Skat track impeller
Sbp fly wheel cover
Rrp straight bars
All new oem motor mounts
Jet dynamics intake grate
Carbon Rrp extended ride plate
Rrp ninja footholds
Compression numbers are 175psi in the front cylinder and 170psi in the rear cylinder. These are pump gas domes
Over all the ski is in great condition the turf on the rails show some sings of wear buts this is a used ski and there are some minor scratches on the bottom of the hull however there are no repairs or gouging of the fiberglass anywhere it’s a clean hull!!
This ski cost In the mid 20s to build so it’s cheap at this price.
I took the ski as partial trade against my comp ski. I have been through it and everything looks great on it.
For more info call 386-264-5508
The ski is located in Daytona Florida
More pics
More pics
