- St.catharines, Ontario
oem cases?
Can yu tell me if the midshaft spacer is necessary? Or will the OEM one (midshaft) work just fine?
ok so from what i understand from reading your thread and talking to badvinny, all you really need to put together the xfs if you have a superjet to part out is:
mid shaft spacer
pump shoe
im putting in a dasa 950 in mine along with a hole bunch of other goodies but i just want to make sure i dont have to wait on anything when the hull and motor come in. thanks the information would be greatly appreciated.
ok sorry to ask another question but i talked with rickter and they said the mid shaft spacer is only RECOMMENDED if you are running a behind fuel tank or if you want more weight on your front. what do you think of that. are you running the fuel tank infront or behind. thanks again.
BEAutiful man!!!! looks sooo goood. i just got another delay on my xfs not going to have it till september now!!!DELAYS ARE KILLing me. They told me that the hulls come with the midshaft extension now.
