Rickter XFS Ninja
Finland
Hi everyone,
Greetings from up north, more exactly northern Europe - Finland.
Not the best place to live if you love skis.
Parts list for the new setup (UPDATE 2021)
Rickter XFS Ninja Competition 2014
Hull (Rickter XFS Ninja Competition Lightweight 32kg)
-OEM handle pole spring
-Rickter XFS Ninja plate short
-Rickter Ninja intake grate
-Blowsion blue billet h-pole
-Blowsion rise bars 52,5mm
-Blowsion custom turbulator chinpad
-Blowsion blue steering kit OVP
-RRP handlebar extensions
-ODI/Ruffian 130mm blue grips
-Blowsion throttle lever
-H20 trim lever
-Blowsion lightweight billet h-pole bolt
-Blowsion blue washers & wateroutlets
-Rickter scrupper valve
-Lithium battery 915gr
-Blowsion billet battery tray
-Blowsion battery tray riser
-RRP billet strap hooks
Pump:
-Skat-trak mag 155 billet setback pump
-RRP 155 trimkit
-RRP 155 pump shoe
-Skat-trak extended driveshaft
-Skat trak 9/15 impeller
-Cold Fusion midshaft spacer
Engine:
-TPE 964
-ATP Flame TS2 Total loss ignition (MSD TL as a backup)
-ATP electrical box
-ATP Flywheel
-Cold fusion engine mounts
-Novi tech 48
-DASA dual billet intake manifold
-V-Force 3 reed's
-Tau Ceti air forced tornado filters
-RRP Carbon exhaust
-RRP waterbox
-Blowsion Black Mamba exhaust hose
-Kart tank
-Cold fusion tank holder carbonfiber
-Blowsion/Jetworks flow control valve
-Cold Fusion fuel filters
-Mikuni Primer kit
-ATP driveline couplers
Cheers
Finland
Forgot to mention the FAQ about the hull: the weight is ~32kg / ~70lbs
Pablo
sqeez bth levrs & lean bk
georgia
Greetings! Beautiful ski. U can't go wrong with Rickter.
If I lived in weather like that 3/4 of the year I would die a quick death! I live in the SE U.S. and it still gets too cool for me. South Florida is my utopia. 75*+ yearly.
Post some good ride pics/vids if you're injuries are healed.
Finland
It's a bit stiff to be honest. Due to the fact that the trim tube comes out from the right side and goes to the left side on the trim makes it a bit hard to hit that trim lever (you need 2-3 fingers). I have adjusted it so that when the pole is close to the hood (usually just before lauching backflips etc) it's not that stiff.
Just ordered a new trim lever, more specific the H20 trim lever. Let's see if it makes a difference compared to the blowsion trim lever that is installed at this time.
Christian_83
Xscream
Denmark
I got a DASA SS 850, same as yours with MSD TL, dual 49FS and PFP. First i a 24kg lenzi carbon sj style hull (144 solas mag) then a BOB G3 carbon 41kg hull (144 solos mag) and finally i my KDX carbon 26kg hull this time with a OEM 155 pump. I felt the same difference, as going from a b pipe to a PFP :)
Finland
What do you think of the DASA engine, or more specific how does the engine perform? Have you had any issues with it or is it more of a "bulletproof"-type of engine?
Regarding the pump selection, what do you guys think: set back or non setback for this setup?
Finland
-14 is the year (2014) the hull was manufactured
Length 210cm
Width 76cm
Height 47cm
And no, i will not convert those to feet since I'm european :D
Christian_83
Xscream
Denmark
@Esca I think its a good engine, that setup right - will give you a good package. no haven't had any issues, really happy with it. I sold it a few weeks ago a and the new owner noticed some scuffing on the pistons (engine has a total of 48 hours from new). I talked with some guys about this issue and it seems to come from doing freestyle and the engine ingesting water.
Finland
Life's good.
850cc PV SS in black
And the Novis
And some random parts
Updates coming when I have a chance to start the assembly. Cheers
