Riva 7 ports cylinder Superjet
Tuscaloosa, AL
Ok. Maybe a better way (layman’s) to say what I think the data suggest is.
For a given displacement (cc) (class rules) a square bore produces best results. The point would end when piston speeds get to high for the length of stroke for a large displacement. The port windows can flow more volume with a square bore for a given volume than a large bore smaller stroke. Does that help?
You do realize some are thinking you are talking about square pistons.
Quinc
Buy a Superjet
California
shhhh you are giving away the next leap in Jetski tech.
dfw
Ive noticed whenever there is a displacement limit and when a tuned pipe is used they like the strokes at or longer than the bore size. I have also noticed much shorter strokes being selected whenever a pipe is impractical, and when the main priority is low weight. You will never see a long stroke chainsaw or outboard marine engine.
