waxhead
wannabe backflipper
- gold coast
Man those cases are beautiful and will run well.
measure the ports from the top of the cylinder and I can give you a basic idea of what the port timing is.
Dropping compression is fine you will lose power but you have to keep the squish tight. Spacing the cylinder opens up the squish and introduces detonation.
R&d pipe are a great pipe but does not have the throttle response of a b-pipe. you can get over that by using total loss.
