The easiest way to add a RIVA Red pipe is to remove the motor from the mounts, slide it forward, install the pipe and water lines, then move them motor back into position and tighten back down. If you don't, getting to the exhaust manifold to chamber bolts is next to impossible. Other than that, when initially putting on the pipe, don't tighten any of the bolts completely until you have both the manifold to chamber and the chamber to head mount bolts all connected. Once you get everything in place, then tighten the mani bolts, followed by the chamber to head bracket bolts. One other thing, when you add the gasket between the manifold and chamber, get some high temp gasket silicone and coat the gasket with it. This will go a long way providing better gasket life.
The RIVA red is a pain in the a$$ to install, but of you prop it right, it makes really good power. Hope this helps.
Scottie
