RN 760 help
Mound mn
I got a RN SJ this past spring with a 760 in it. I have had a lot of fun learning to ride this thing all summer. It's a world of difference from the old 650sx I have. Now that I have the hang of it I want to make some upgrades. the previous owner did the swap, installed impeller, ride plate & intake grate. I was wondering what power mods I should make? I ride mostly on lake's chasing boat wakes. and was wondering about increasing the compression from 150 to 170 or 175 but I'm not sure what head to buy. Also I am not 100% sure if the B-pipe from a 701 would work on the 760? I have been searching and have not gotten any real answers on weather or not this will work.
Thanks.
oakland
B pipe will work you either need a 62t manifold or drill out a 61x id bring compression up to 180 ada or any other o ring head will work pipe is a must head second
Mound mn
My thoughts are the mod for the 760 being bigger + it's easier to install do to it being shorter. Or at least that's what I have read.
bored&stroked
Urban redneck
AZ
Mill the oem head to 180psi no need for aftermarket. I'd go limited pipe, the 760 already has poor low end power and the mod pipe won't help anything there. Flow control valve too.
