RN hull weight?
Crab
thanks darin...noswad!
Seattle
Anyone know what a dry bare hull should weigh in at? I'm at 113 with just a couple of minor things left on.
Crab
Seattle
my hull weights 137 with EVERYTHING from the firewall back pump prop intake grate mid shaft foam scupper ect from the midshaft back
and thats after reinforcing the crap out of it
All I left on was the pump shoe, wet foam in the rear, hood latch, nosepiece strap, sponsons, and a couple nuts and bolts. I was skeptical, but weighed it 5 times, then checked it against my weight and my daughters.
Two years ago, my bare RN hull, with fresh foam, and heavy reinforcing front and back, weighed in at 120lbs.
This same hull now weighs approximately 110lbs without any foam.
WAB
salty nuts
coastal GA
My squarenose hull weighed 87.5 lbs after sitting up dry for 2 yrs. That's w/o hood, but with footholds, turf, & pump shoe. and with out reinforcing
