Custom/Hybrid Rn re foam tom21 adjustable foothold install
ph1lthy11y
Cummins hauls my ski to the water
california
Thought I would share some pics with you guys
first what the tray looked like before
getting turf off
found some surprises
as swapmeet would say really the guy before me used bondo to fill hole on top rail and his glass job sucked you can see in pics ^^^^
ph1lthy11y
california
Cut out old holds started fitting new holds
also widened the tray a little
and cut the footholds to shape
as you can see had to cut foot hold to clear exhaust
not to clean but it works
next it was time to re-foam
got tired and decided to use a pressure washer much faster
had to plug some holes in the firewall
ph1lthy11y
california
made some plugs out of my cut outs
fits pretty good next 5200
a little more
cut out a space for drain
used a wire brush to shape the foam
next time to use thick epoxy resin to glue in tray and footholds
next time to start filling gaps with foam
ph1lthy11y
california
then start glass work
sanded everything straight and final glass in total i have 3 layers of cloth on sides and 1 layer of biax across tray
then started turfing yea i suck at turfing
and i made a drain out of a ss t nut and a ss bolt with a o ring behind it for the exhaust side
thanks for lookin
tom21
havin fun
clearwater FL
they are super comfy 3/4 plush top and bottom
ya see? this is what happens when you dont stay on the site all day every day!! how did I miss this?
I think your install looks killer and your turf looks great from here.
thanks for taking the time to put it out there
