- Brigantine, NJ
is there no need(benifit) to make the intake tunnel bigger 4 surf....,wont you be under feeding the pump???
I haven't noticed any downside to maintaining the stock pump tunnel. I've been running the same set up on my other FX for over 2 years now and it rips. I think you would want to change it if you were trying to build build a flat water ski, but for surf and wide open high speed carving on flat, this set up works great. Having the pump set back 2-3/4" keeps plenty of water in front of the prop for good hook up.
