Dustin Mustangs
uʍop ǝpıs dn
- Holland, MI
I just tore down a 62t/61x to send the cylinder out to get ported. The small ends of both rods were purple; I assume because of heat. Is this normal? If not, what does this mean??
Also, is there any reason to run more than one washer per side on the piston pin between the piston and the bearing/rod? I could have sworn I dropped one down into the case but I've accounted for four of them total and I can't seem to find anything down in the case. I'd really rather not split the cases to make sure as it held pressure perfect before the tear down.
:scratchchin:
:scratchchin:
