Custom/Hybrid Rok hull breather tubes?
Well, I installed tubes in. Right in front of the hand holds, maybe 4 inches from the hood lip, the hood starts to curve a little in that spot so the tubes point towards the back a little, so they perfectly slide in between the motor and the tank. and there is plenty of space between the liner and the hood in those corners. and glad to say, the ski is still dry as a bone on the inside...:arms:
Nice-what handle pole are you running?
Sent from my DROID RAZR using Tapatalk 2
USA
honestly...no, but my setup is out of tune. I was trying different set up on my pipe at the same time so even if there is a difference I would not be able to tell. I should of done one thing at a time. really wanted to drill some holes in the front hood for more air to pick up, kinda like the stock skis have, but that would defenitely pick up more water at the same time.
DK-Freestyle
2011 World Champion
Oakley, CA
The tubes on your RRP will be more than enough to feed your engine. I blocked off the breather tubes on the hood of my BOB G3, so the only source of air my 1105 is getting is from the RRP tubes.. runs perfectly fine.
