JimTMich
SXi Pro and RN SJ
- at the gym
Could I be detonating or pre-igniting?
My TL timing curve is flat at 18 degrees, so I have a lot of timing up high where I shouldn't.
I detonated a piston to death 2 summers ago with this ignintion and this pipe and it is behaving the exact same way......
I will lower the compression, if that helps, then I will retard the timing, raise the compression and start the jetting all over again. Lets hear it for race gas and patinets.
