RRP Mount To Low
TN
I installed the RRP pole bracket Mount and the fork bracket is to low for the stock hood forks. Anyone tried the RRP Adjustable Hood Forks and if it will drop them enough to fit in the RRP Forks Brackets that came with the RRP Bracket???
TN
Do you have the RRP bracket for SJ or the RRP Rickter bracket for aftermarket hulls?
It’s the superjet mount but the hood brackets looks like they are made for a a lower aftermarket hood. So I bought the blowsion adjustable hood forks going to try them since you are able to drop them down. But I truly think I need to just switch the RRP brackets back to the stock Brackets since they mount lot higher up. So when I take the hood off the top of the hood clears that nose that covers the pole bracket. I do wanna buy that lower hood with a new nose tho it makes the Saj look pretty good imo
