rrp pole- how to shorten
curt248
01 superjet 94 fx1 97 xp
Chicago IL
This is silly. The pole wont shorten once installe . I loosen the bolts wont shorten. the steering cable is a bit squishe in there. Coul that effect it? It was fine before i installe the cables an hooke up the turn plate an bars. This is so frustrating. The entire reason to buy the rrp pole is to a just it.
I ust be issing so ething. Please help guys. Thanks.
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
i think you are missing a "D" and am "M" on your keyboard.
:pancake:
curt248
Chicago IL
You figured out the code. I have no idea why the keyboard in the cafeteria at work won't allow you to type d or m without changing tabs. It's really strange and frustrating.
Where did you reroute the steering cable too and how did you do it?
curt248
Chicago IL
I just spoke with a rep from rick roy racing. Great customer service. He called me just now at 11:40pm. This was only 5 minutes after I sent an email saying he could call in the next 15 minutes.
Apparently the rrp pole comes with an adjustment of +1 to -2 inches. If you want more than that, as I do, the silver poles need to be cut with a pipe cutter. I still have on the long stock steering plate, so I'll need to go shorter than -2. The nice thing is that you can buy new poles for $39 each (~$80 total) if you cut them down too far and want to go longer after buying a shorter turn plate.
I wish I knew about this before ordering though. I remember reading about another pole that could do a -5 inches adjustment, but not to infinity and thought that wasn't enough adjustment. The -5 could be done at any time without cutting any poles.
Motorheads5
Livin the generation gap
ketchikan alaska
The janitor's use the keyboard at nite and it is Sperm infused !Sorry someone had to tell ya lmao
