If you’re ordering from Amazon I ordered a Seaflo pump which is an exact copy of the older Rule , so the brackets for the older rule will still work .Is anyone making a bracket to hold the new style rule 500 bilges, specifically for a FX Cruiser? I want them to put a bilge in our new rescue ski and would like to use a bracket like what I have on my superjet. Also we will be using a rule float switch. I don't have experience with the new style bilges or the float switch. We will glue them down if we have to. Being able to order the part from Amazon is a lot easier for handling the order than trying to get them to order from some other 3rd party. Bureaucratic stuff.
Jetmaniac sells a bracket for the SJ and new style 500gph Rules. I have one in my hull and it fit fine, I had to flatten it and rebend it at a different point since my hull is different to a stock SJ but it was a great purchase. My old glued one was broken and seemed to break fairly frequently.
It mounts on the midshaft bearing housing which I assume are different so likely not. Send a photo here and take a measurement from one of the bolt holes to the bottom of the bilge and I will measure mine and tell you.Will the SJ brackets fit in a 2024 FX Cruiser HO? That's the part I'm mostly asking about.
