- Edmonton, AB, Canada
Do any of you guys have pics of how you mounted this thing? I'm kinda at a loss for where to mount it and how......
wow you guys remove your toolkits? man that little crap set has saved our ass's on the lake more then a few times! Pullin spark plugs to bangin rocks out of pumps.
Same here. I use this toolkit almost every time I am on the lake. Usually something happens when were are way out there. It has saved our ass many times. Mine stays in the hull:biggrin:wow you guys remove your toolkits? man that little crap set has saved our ass's on the lake more then a few times! Pullin spark plugs to bangin rocks out of pumps.
i have mine under the shaft bolted it down next to the oe one , 6 years going strong . i used 1100 , 750 takes to long after a sub or if hood comes off , never know
I use the 3/4" fitting with my 1100...just get a reducer for the hose. The water shoots out like 7 feet from the hull!
My suggestion is don't use silicon or 5200 they come loose eventually. Get the devcon 2 part plastic welder and it's there for life.Has anyone mounted one in a SJ?
anyone have a picture of how you mounted it?
