Rule Mate 750
ANGOLA
i have mine under the shaft bolted it down next to the oe one , 6 years going strong . i used 1100 , 750 takes to long after a sub or if hood comes off , never know
BombThreat
'Diggity
Johnstown, NY
wow you guys remove your toolkits? man that little crap set has saved our ass's on the lake more then a few times! Pullin spark plugs to bangin rocks out of pumps.
Idaho
Same here. I use this toolkit almost every time I am on the lake. Usually something happens when were are way out there. It has saved our ass many times. Mine stays in the hull:biggrin:
MattyBoom
Amsoil Rep/Machine Shop
Long Island, NY
What thru hull fitting did you use? the 1100 has a 1-1/8'' hose barb.
Id like to run a 750, because i have a 3/4'' fitting, but wouldnt mind running an 1100.
I have 2 500 rule and they have lasted fine with 5200 but I will try the plastic welder this time.
I was more curious on how the rulemate 750 fit, as it's much larger than a traditional 500 rule
