Other Running OEM f/a on Blackjack carbs
Does anybody mak and adapter so you can run OEM 44mm flame arrestors on BlackJack carbs? I have always had carbs that bolted right up but looking at the "horn" on the Blackjacks I don't see any options.
I swore I would never run open f/a again.
Chad
For what's worth the thrust adapters require the removal for your carbs to take off or install. IMO they get in the way if you need to adjust screws etc. I like the wammerstyle better because you can take the whole Unit including the base just like a regular FA.
