Freestyle Runnning RRP tank and battery location?
I will be installing an RRP rear tank and running a 2g kart tank in my ninja. Where do you guys put your battery? i will be running a featherweight or a ballistic 16c. Pics and info would be greatly appreciated.
I've fit a battery tray between an engine and kart tank before. Both side ways. Pfp pipe. It's tight but that's a good thing
I don't have room for that. I'm running a 4 gallon jazz tank. My only options are in the rear next to the midshaft. I need either a small battery box or a battery "shelf". I can't find anything other than blowsion crap.
Any room under the pipe next to the tank on the port side?
I think that's where I'm going to put my battery, but I'm just running a 3 gallon jaz tank with rear rrp tank.
My battery fits there, just have to figure out how to get it well secured.
There is room but, there is alot more room in the rear of the ski.. What kind of battery tray do you plan running under the pipe?
oakville
I made this holder for mine. Don't have a good picture of it in the ski but the last pic you can kind of see it too right. I used UFO mounts and then just bolted it down
Not sure if this helps with the cart tank too. I think djr just came out with new battery setup for a nice side/rear mount. I did switch to a much larger batter , but same spot. Pm me if u want more pics.
