- Stouffville, Ontario
So here's the sitch
We have a WB1 with a Kawasaki 1100 and a WB1 with a 701 in it. Both skis are relatively new to us however we did build both drive-lines. I'm looking for a simple solution that is plaguing both skis
The issue
Both skis start great on the trailer, have good compression, fresh batteries and tight connections. In the water, both skis fire up great, and rev up like they should, HOWEVER, intermittently they both will die while riding. Flat out die. As if you pull the landyard. Both skis have new SS switches and we have disconnected the OEM connection and ruled out that issue. Fuel filters on the skis have been cleaned internally and new in line filters as well. We've started swapping major components (Carbs/ Eboxs) however would like to hold off until I get some input here.
This happens randomly at 1/8 throttle, through to WOT (Which physically hurts when the 1100 dies mid corner) and at odd intervals. Sometimes Every 5/10/15 seconds, up to every 3-4 minutes. It never happens at idle on or out of the water.
For the moment I won't list out the setups of both skis because I'm hoping someone knows something obvious that could be affecting both skis here.
Thanks for taking the time to read this and hopefully sharing your much needed knowledge
Mike
The issue
Mike
