SBN 44's 46's?? how do i tell what i have?
cycojon
addicted to my superjet
riverside ca
where do i measure them at? is it the top of the carb where the FA bolts on? or at the base where it bolts to the intake?
at the top the ID measures 46.59mm
at the bottom the ID measures 45.28mm
so are they 44's or 46's?
thanks
cycojon
riverside ca
they are black, the cast in step on the bottom bore is about 5/8" long so i am guessing they are 44's.
i have a stock 701 in my RN SJ, and i am installing a limited chamber
B pipe, should i go by FP jetting specs for stock 38's? all i am looking for is a starting point for jetting so i don't hurt anything!
sjetrider
HMMM familiar set up, I suggest reverse jet 100 main / 110 pilot w/ 2.3 n/s and 95g spring & 1.250 turns out on top and bottom to start. Just my opinion. If they look like factory painted black they are most likely 44's.
