- Michigan
I’m just getting around to installing mine now but I am also switching from stock stator w tbm stuffer to solas, so with multiple variables it won’t be very scientific.
What engine in front of it? Cavitation from a dig?The SBT prop I tested was almost like a chrome finish. Again it was small feeling and let the motor rev to the limiter
smaller than 9/15 hooker and way smaller than 9/15 solas YQ big hub
I just pulled a Solas Concord "14/18" small hub out of my ski and measured anywhere from 11-13 leading and 17-18 trailing.Can you measure another impeller using the same gauge like a hooker or stock or something so we can compare. Also thank you for being the guinea pig!
Yes, that is what I was implying. It is manufactured to be setback against the stator more than the Solas. It also fits my wear ring tighter, but that might just be two seasons of Daytona Beach sand extrusion.or just way its MFG.
Sure looks like the stock yamaha one, maybe it's just the integrated hex.
I though the Adonis ones were supposed to be polished?
This got me thinking of ways to check the angle of my impeller blades. I have several devices for checking angles for construction. After some testing the best one was a Harbor freight magnetic angle finder. I made sure I was on a hard flat surface and checked that the guage read zero. I then checked several impellers I have and the guage read spot on. Only can be used on leading and trailing edges but that's all I can correct anyway.
https://www.harborfreight.com/dial-gauge-angle-finder-34214.html
How you liking hull?Burned a tank today, first time with my Rickter in the surf. The Adonis impeller is a significant improvement over the Solas that was in the ski. Felt stronger off idle and a bit better hookup in the whitewash. Pretty happy with it overall, and the price was great. I'd like to compare it to an OEM superjet impeller in the future.
Very much, it feels very similar to a superjet. It felt very comfortable right away and was an easy transition. I dare to say, it could be better with a couple inches taken off the back.How you liking hull?
