You do know they don't ALLOW you to open up the engine if you are sending it back for warranty right, I hope they don't try to to get out of fixing their screwup, stuff like this is exactly why I stopped using their engines.
I had a 4tec seadoo I installed the engine on, on the test ride the oil light came on, I checked the oil level and it was super low, turns out the rubber valve cover gasket had split , pretty obvious as oil was all over the head and in the bilge, they wanted me to pull the engine and send it back, It got pretty heated and I told them they were out of their Fing minds, I grabbed a used OEM valve cover gasket , installed it and ran the boat again, then they wanted to say I violated the warranty by replacing a valve cover gasket, what kind of company does poop like this , I just saved them an engine and they wanted to violate my customers warranty , the stuff they do makes no sense, there are many other stories I could tell you here .
The company as a whole does not care about the customer or their reputation, they have moved on to other revenue streams such as Watercraft Superstore, buying out hydroturf and 4xpro their ATV axle company, most people don't know they started out making CV axles for Automobiles before getting into the PWC business.
